My Adobe Frame Maker 9.0 has encountered a problem. While creating a file it has thrown an error message. Have a look at the screenshot. I have no idea for the error message. If you have any idea for the error message, please help me to solve the problem.
Frame Maker
Filenames ending in,mif cannot be saved in Document format.
Save headings.mif as MIF instead?
Hi there user:
There a lots of genius people. So then, there are also lots of problems to encounter. Funny, but that’s true.
You’re just one of so many head-scratching users of adobe frame-maker, having problems. Anyway, I suggest you to visit helpx.adobe.com. You will learn a lot here aside from trouble shooting this kind of problem.
Thanks for visiting and asking via techyv.com
Hi dear.
This is not a big problem. When you see this error message, click on yes on save those files as MIF instead. Doing this will not do any harm to your files. If you want to solve this problem permanently, you can follow the instruction given below:
Adobe frame maker 9.0 shows you this problem. So save your files in frame maker 8.0. Then open frame maker 8.0. Go to the options and click on 'save as'. Then select frame maker 9.0. Then again save your files and your files will be saved in frame maker 9.0 bookbuild. Your problem is solved now.
Thank you for your question. Feel free here.
