arifnu09
Posted on - 08/11/2012
Long time I am using Illustrator CS3, and recently I have found problems, the swatches palette, brushes and every kind of tool and palette are disappeared and an error message is showing.
The Document 'print.ai' contains elements that are managed by plug-ins that are not currently available. You can delete or expand these elements, but you cannot manipulate them in other ways. The missing plug-ins are listed below.
The document 'print.ai' contains element that are
elements but you cannot manipulate them in
other ways. the missing plug-ins are listed
below.
Adobe Art Brush Plugin (ArtOnPaths.aip)
Art Brush (ArtOnPath.aip)
Illustrator expert please give me any ideas about this problem solution. I would be grateful for this solution.
Thanks in Advance.
Adobe Illustrator CS3
Adobe Illustrator All Window Disappeared
Hi!
Have you tried to delete all your Adobe components and uninstall it from your computer?
After doing this, try to install it back again. Or just install the missing plug ins. If these doesn't resolve your problem, try to reinstall the Adobe PostScript drivers from here:
For Windows users
For Mac Users
I hope you can be able to solve your issue with the above solutions.
It seems that there are some important illustrator components that are missing and as a result inhibiting its proper functionality. You will therefore need to update the software in order to resolve the issue, or you can just get its most recent version and then install it.
Nicke
