Paul C Pina
50 points
Posted on - 01/21/2014
I have this error in Adobe Illustrator and don’t really know what it means. I am a newbie with Illustrator and I am only using it for college projects. Now I am stuck with this error for 2 days at the same project. I need someone to help me with this error and explain me what happened and where I did something wrong ?
Thank you !
Adobe Illustrator
Artboard size cannot be longer than canvas size.
Adobe Illustrator Artboard size cannot be longer than canvas size
Hey Paul,
The reason why you are getting the error message using Adobe Illustrator is because your project size exceeds the required limit, which is 200 inches by 200 inches. Once you pass this limit, some of the MAPublisher tools may not work properly. However, to fix this you can change your document size to the required size, depending on the Adobe Illustrator version you are using. You can get more information from the www.graphic-design-employment.com site. I hope this information helps.
