tharindu
Posted on - 03/05/2012
Hello Guys,when i was trying to launch Adobe Illustrator CS4 I always end up with error message "Unable to load DLL amtlib.dll" My operating system is windows 7 64bit, I tried to change the compatibility mode of the application,but it didn't work. Can anyone please give me a set of steps to execute the application correctly?
Recursion too deep; the stack overflowed.
Unable to load DLL C:Program Files (x86)AdobeAdobe Illustrator CS4Support FilesContentsWindowsIllustrator.exe->amtlib.dll
Adobe Illustrator CS4 help needed
As you already know that the DLL files are very important for any type of application to run properly. I myself use adobe products and most of them use this amtlib.dll file in their directory.
Perform a reinstallation of the software so that the missing file is replaced automatically during the installation process.
If it still gives the error then look for this file over the internet. There are many users who have placed this file on the internet for all others.
Download the file and copy paste it in the respective directory. Now start the adobe illustrator.
.DLL error of the application may cause spoiling some Illustrator data. Check it for corruption.Â
Another way scans your .ai files for errors:
http://www.illustrator.fixtoolboxx.com/
