jing55
Posted on - 09/19/2011
Some of you that could help,
What does this mean?
I am creating a different vector artwork in my project in adobe illustrator, when I try to paste it, it gives me this message.
Where do I have to go to put a check on that AICB checkbox?
Where is it located?
Thanks a lot.
If you are attempting to paste vectors from Adobe Illustrator, please check the AICB checkbox in the Adobe Illustrator File Handling and Clipboard preferences.
Advance thanks to someone that could help me with this.
Adobe Illustrator problem. Where can i find that AICB settings?
To solve this problem first uninstall your application program and then install the others application program. This will skip collusion. If it is not working then use other option.
If in your computer you install some similar application program in a same time then uninstall one program, this problem occurs. Similar application share similar file they have and uninstall one program can take that similar file with it. So this error shows.
Other option is go to run and type “msconfig”. And press enter. Now click on services tab.
Here stop all Microsoft related services and restart computer. And then try to install this application program.
