Adobe Indesign Entry Point not found error
I am trying to use CS5 suite with a network user using a compulsory profile. But I get some problems while loading this. Then I get InDesign and also rename file extensions on certain plug-ins. But then another error occurs. And that is:
After hitting the OK button and redoing the process, the result is still the same. The message doesn’t disappear.
I also tried to download video streams but I got the error shown below:
C:Program FilesOrbitdownloader\orbitdm.exe
Windows cannot access the specified device, path, or file. You may not have appropriate permissions to access the item.
[JavaScript Application]
Cannot run executable: [Exception… "Component returned failure code: 0x80520003 (NS_ERROR_FILE_EXECUTION_FAILED) [nsIProcess.run]" nsresult: "0x80520003 (NS_ERROR_FILE_EXECUTION_FAILED)" location: "JS frame :: chrome://grabpro/content/common.js :: execCommand :: line 258" data: no]
So, please help me to solve this error.
Answered By 590495 points N/A #102631
Since you are having a problem loading Adobe InDesign CS5.5, try uninstalling and then reinstalling the application to fix any corrupted files and to restore its settings back to default including some of the settings that you might have customized. If it does not work, check if this version is compatible with your computer.
Your computer must have at least a Pentium 4 or an AMD Athlon 64 processor installed on the CPU. To be able to install and use Adobe InDesign CS5.5, your computer must be running on Windows XP Service Pack 2 or Service Pack 3, Windows Vista (Home Premium, Business, Ultimate, Enterprise) Service Pack 1, or Windows 7 operating systems.
You must have at least 1 GB RAM installed on the CPU. The more RAM you have, the better. This application requires 1.6 GB of available hard drive space. You must also install Adobe Flash Player 10 or later versions.
Check your computer if it is compatible-enough to run Adobe InDesign CS5.5. The information above will help determine the application’s compatibility with your system.
