saabreen
20 points
Posted on - 10/23/2011
Hi TechyV members!
At the end of the project I was working on Adobe Encoder popped this error.
It only showed this message at the very end of the process, and I actually thought that all the clips were done.
Why would it process everything only to hang up at the end? I'm confused.
Does anybody have an answer to this and how it should be fixed?
A million thanks guys!
Adobe media encoder has encountered an error.
Jackman
Adobe Media Encoder Debug Event
The reason could be that you removed another version of Adobe media encoder from the same system to be precise the computer. To get your encoder working close all Adobe applications then in Windows explorer go to C:ProgramFilesAdobeAdobepremiere pro cs4 then right click on the Adobe premiere exe pro and choose to create a shortcut. Rename the creating Premiere, and note the name of the shortcut should be Premiere. Click to open another instance of windows explorer then go to C:Program FilesCommon Files Adobedynamiclinks then get the Premiere shortcut you created moved to the dynamic link folder. You will be sure to avoid this error in future.
