Hi Friends,
I was using Adobe Encoder for one of my projects that suddenly an error message popped up on my screen.
The screenshot of the error is as follows:
Adobe Media Encoder Debug Event
Adobe Media Encoder has encountered an error.
[…SrcWinWinFiIe.cpp-785]
Continue
I'm really confused and worried as my project was about to end.
Does anybody have an answer to this and how it should be fixed?
Waiting for your suggestions thanking you in advance.
Regards
Daniel
Adobe media encoder encountered an error
Try restarting the computer. Click “Continue” then exit Adobe Media Encoder and then restart the computer. If this doesn’t work, run the program as administrator. Right-click Adobe Media Encoder then select “Run as administrator”. If this doesn’t work, try to uninstall and reinstall. Download the free version of Revo Uninstaller and install it. Once installed, start Revo then select Adobe Media Encoder among the applications and click “Uninstall”.
Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, exit Revo Uninstaller then install Adobe Media Encoder back.
