reythareyne
Posted on - 09/02/2011
I am using Adobe PhotoShop CS4 now I am trying to open PSD file in it but I am receiving below error. Tell me its reason and how can I remove this error.
Adobe PhotoShop CS4 Extended
Could not complete your request because it is
not the right kind of document.
OK
Luke Dan
5 points
Adobe Photoshop CS4: Error on opening PSD File
Hi Rey,
About your problem the error state that your opening a wrong document. Have you tried to open it with other programs? Or have this file been opened with the same program which is PhotoShop CS4?
First be sure that it is the correct program for the file. You can also check other program that may run with this file. By right click on the file then click open with. You can then select programs recommended by the computer to you. These programs may open the file.
It is also possible that there are errors on your system. And I recommend running a registry scan.
Click the link for the program that checks the registry. It will help solve errors that prevent you from opening the files.
Hope this helps.
