Guys,
I have downloaded and saved Adobe Photoshop CS5 in my computer which I installed before by double-clicking it. Then I uninstalled it for some reason. Now when I am trying to install by double-clicking it, it says “You cannot open this application because it may be incomplete or damaged.” How can I install this application? Thank you
Adobe Photoshop CS5 not installing
There are a lot of problems why your Adobe Photoshop is not installing. The first one that comes to mind is that you’ve downloaded it from the internet, and it’s no good, probably with viruses, or the software is illegal. You can try downloading a new one, which has better reviews, and try that one. The best advices I can give you are that if you really like the software and know how to work with it, and then buy it. You will have access to every update released by Adobe, and you can add tools very easy to the original version.
