Adobe Photoshop CS6 Extended error
I tried to crop an image I received an error message when I was running Adobe Photoshop CS6. I can’t resolve this issue even after the reinstalled this program. How can I fix this problem with the proper solution? Any help would be really appreciated.
Could not build the Crop preview because of a program error.
Answered By 0 points N/A #181208
Hi Joe,
                If you are using a Wacom pen this error often occurs it may be that the pen was so sensitive that it was moving advance or ahead as you write. There are a couple of solutions you can try you can reset the tool, reinstall the pen driver. However some instances those steps does not work at all times, but I can suggest an unusual step try to slow down the Wacom pen so it will not be as sensitive and it will move real time as you go along the writing tablet.
