sally
Posted on - 09/16/2011
Hi guys,
I have a problem with my PhotoShop program. It runs fine for a while then it stops responding.
Anyone with any idea what could be wrong? Thanks
Here is the message:
Closing PhotoShop Elements
Adobe PhotoShop Elements has encountered a problem and needs to close.
Error code: c0000096
Address: 49e7629
OK
Adobe Photoshop Elements has encountered a problem
The PhotoShop Elements 3.0 needs to load the Quicktime libraries to function. The Quicktime components crash automatically when the software is in the phase of 'Initializing Threads'. There is no specific reason why this problem occurs. But you can check thoroughly what happened during the crash by using the Process Monitor tool. It has a strong monitoring and filtering  potential. It is the best application to use for troubleshooting and virus scanning.
The Quicktime components can be located in the C:Program FilesQTSystem folder. To solve the issue, you can rename the folder to 'QTSystem1' to avoid the glitch in the system. It will direct you to the software itself. You would be able to continue working although there is no assurance that there would be an effect on Photoshop's efficiency.
Feel free to ask if you have any queries!
Rizza
