Adobe Photoshop entry point not found
Hey Guys,
Before my program software program works well. It is ADOBE Photoshop CS3, but when I tried opening it again a bit later an error pop up. It tells that the entry point not found. The message error is below.  I tried to look for that DLL but nothing found and nothing solve to my problem. How can I overcome this problem? Any idea?
Photoshop.exe-Entry Point Not Found
The procedure entry point_CFBundleCopyFileTypeForFileData could
Not be located in the dynamic link library CoreFoundation.dll.
Answered By 0 points N/A #109298
Hi Mon,
This kind of error could be as a result of a dll version conflicting. Ensure before we jump to conclusion that you have applied all windows updates. Also update all your scanners and drives to be sure that this is not the cause of the error because they can also be the cause of such errors during start ups. The operating system could also bring such concerns. To troubleshoot it get an installation of Photoshop 10.01 you can get this from this website.
 If this doesn't solve you problem then check your plug-ins you might be having multiple  installations of dll's different versions.
