Adobe Photoshop error message has occurred
While working on “Adobe Photoshop” I can’t open files like extensions of .eps. But I need to open it. Can anyone please help me in this regard?
unknown or invalid JPEG marker type is found.
“Adobe Photoshop
Could not complete your request because an unknown or invalid JPEG marker type is found.”
Best Answer by Flinder Matthew
Answered By 0 points N/A #176515
Hi there,
                If you cannot open a specific file or different kind of file extension type in your Adobe Photoshop, all you need is to convert it first to a file type that your Adobe Photoshop can read, like for example a .jpg or .jpeg file type. After converting it, you can try to open it now on your Adobe Photoshop.
Hope it helps.
Answered By 0 points N/A #176516
Hello Julio,
This common error appears when you try to change the file extension or type manually by editing it's creator or extension. It has a simple solution to fix the error you are getting. Open the files one by one in Photoshop and  save them separately with the desired extension you want to use. You will face no problem again in future.
Thanks
