Adobe Photoshop Plugin creating disorder in equalizer lights for iTunes
Adobe Photoshop plugin creating a disorder in my equalizer lights for itunes. Please tell me how can i fix it? And can it be target to darks, midtones and colour effects?
It may be occurred for huge combination of colors in the image. For which it become harder to identify actual color you want to light up or down with equalizer. First you can select the color and control the equalizer light.
You can use equalizer lights separately for darks, midstone. It can be target to darks, midtones and color effects.
If it's not fix yet, then go to control panel, uninstall adobe photoshop and after restart your computer, again install this.
