Adobe Premier 9 – No Disk error
Does anybody have any idea of what is going on with my Adobe Premier 9? I was editing my video and was doing some finishing touches. When I was trying to preview it, I got an error message stating: Adobe Premiere Elements.exe No Disk.
There is no disk in the drive. Please insert a disk in to drive Device Harddisk3DR3. The message will only disappear when a disk is inserted although I am not writing my video into it. I need your suggestions on resolving this. Thanks a lot.
Answered By 10 points N/A #120925
The problem could be a result of the cable connecting the hard disk drive to the external hard drive being loose, or it has completely disconnected and therefore the hard drive cannot be detected. You will need to open the system unit and fix it, connect the cable properly to the hard disk drive.
It may also be a problem with the jumpers not being configured properly, that is if the hard disk drive that you are using is an IDE drive, and therefore you will need to make sure that the jumpers are in their rightful positions. Make sure that you have not replaced hard disk drive jumpers with DVD drive or floppy drive jumpers.
Also, if you were saving the project on an external hard drive, then the drive might have disconnected and therefore you will need to check if the problem is with the cable or the ports.
Regards
Thompson Locker
