What is wrong if adobe keeps crashing? I have 4GB RAM and 64bit OS.
Adobe Premier Is Always Crashing
When Adobe crashes, there could be a lot of reasons for it:
The preference, project, and/or preview files might be corrupted
The clip may be corrupted
The computer may be faulty
There are many work-around to have any of these issues resolve:
Update the Adobe Premiere
Update the graphic card driver
Disable the graphics hardware acceleration
Use Nvidia Control Panel in setting the Threaded Optimization to off
Turn off the Enable GPU Playback
Re-create the PluginCache of the Adobe Premiere Elements
Uninstall the Nvidia 3D Stereoscopic 3D drivers
The solutions above are all workable depending on the exact issues you are getting when your Adobe crashes.
neil max
Adobe Premier in my pc also crashes very often. I tried uninstalling it and then reinstalling it, but it brought no difference. That is when I saw this post and tried all the steps recommended by the expert and found my Premier working smoothly! Thanks for the help, thank you very much.
