Adobe Premier Pro has stopped Working
Hi dear,
I am trying to install Adobe Premiere Pro but it is not working properly due to this problem i can't install this software i download other version of this software from the net but same problem appears.
Please tell me its solution.
Detail of Error
Microsoft Windows
Adobe Premiere Pro.exe has stopped working
Windows is collecting more information about the problem.
This might take several minutes.
        Cancel
Answered By 0 points N/A #116113
Jessieebannon,
There are many reasons why your installation would not continue. However according to your description of the problem, We can safely say that the installer is not the issue here since you must have started using an installation disk first and then tried installing a version downloaded from the internet with the same results.
This could mean that;
a. the hardware requirements of the software are not present in your machine
b. there is a failing hardware that is detected by the installer and it stopped the installation
c. there is a missing file that the installation requires and is not detected.
d. there is a faulty application running in the background that may be interfering with the installation.
e. your anti-virus application may have fail-safes against changes made in the registry and program files
f. you did not run the installation in ADMINISTRATOR mode ( only in VISTA / WINDOWS 7 )
g. you are not using an ADMINISTRATOR profile
if you have ticked off and corrected everything in this list, and the error still persists, you have a failing hard drive.
Happy Computing,
