Hi dear,
I am user of Adobe Premier and receiving this error please provide me help.
Detail of Error.
Microsoft Visual C++ Runtime Library
Runtime Erro!
Program:…Adobe Premier Elements 7.0Adobe Premier Elements.exe
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application’s support team for more information.
OK
Adobe Premier Runtime Library Error
Try to Disable the DLA or Direct Letter Access by shutting it off from the disc drive context main menu or from your disc drive “Property Settings”
Shutting from the context Main menu simply do the following:
Launch your “My computer” right click the “Disk Drive” that you are trying to establish. If ever you see a “Use with DLA” selection, uncheck it, after tapping the “Ok” click now the “restart” button in your computer.
Shutting from the Property settings simply do the following:
Launch your “My computer” right click the “Disk Drive” that you are trying to establish. Then choose “Properties” right then click the “DLA” icon, disable the “Enable DLA” on the selection tab. Tap the “Ok” then “restart” the computer.
You can also try to make another account of Local Administrator on your computer system and the try to establish the installer.
