Fiannfriday
Posted on - 08/19/2011
Hi dear,
I am user of Adobe Premier and receiving update driver error.
Detail of Error is here:
Adobe Premier Elements
We have detected generic Microsoft’s display driver on this machine. To get a better and faster playback performance, please update your display driver.
Display driver details: Microsoft Corporation – GDI Generic 1.1.0
OK
Provide me its solution thanks in advance.
Adobe Premier update driver error.
Hello dear,
Yes this is a valid error and it’s not the fault of your software adobe but there is a problem of your computer hardware named graphics. Actually this type of errors is only given when there is no any support to that software from your computer side. I mean to say that your present graphics card or resolutions are not able to support or handle your software update may be because those updates are more enhanced and faster ones. So the best solution for you is that you can upgrade first your pc’s graphics and then again start updates of your adobe. I hope these suggestions will help you to fix your problem.
THANKS.
