ricarey
Posted on - 02/18/2012
Hello everyone! I hope that you would be able to help me out with my problem. When I tried to install Adobe Premiere Elements 8.0, I encountered an error message that says: "Error: 1935 Installation of Assembly component failed".
After displaying this error the installation process completely stops. I tried to clean the registry, disable the services, and set up programs, but the error still occurs.
I am currently using Windows Vista Home Premium Service Pack 2. What should I do?
I have provided a screenshot of my problem below to help me illustrate the issue that I have encountered.
Adobe Premiere Elements 8.0 – Setup
Error 1935.An error occurred during the installation of assembly component
{CE3230AC-E72E-3EDF-8A57-87FCE1CF2629}.
HRESULT: 0x80070005.
Any suggestions from you would be greatly appreciated.
Thanks in advance.
Adobe Premiere Elements 8.0 Installation Error
Hi
The problem you are telling is that you are trying to install the adobe software but it not gonna install into your OS windows vista. The picture looks like that there are 2 problem which you may encounter are that:
1. Either your software is not correct there is something missing in the backup and that is why this error is appearing so for this you need to replace the medium from which you are installing this software and then install the software it will work.
2. Other option is that your window is not compatible with this version of the software so you need to check it out and solve this problem.
