When I try to open Adobe Premiere program I was stuck with an error message. I am getting this error message while it is the process of loading. For more information, I have windows 8 64-bit operating system, 250 GB hard disk and 4GB RAM. Do I need to reinstall the program? Please help me to resolve the error and find solution. Thanks.
LoadLibrary failed with error 126: The specified module could not be found.
Now I have installed a premiere and get the above error message while attempting to open.
This issue is occurring only after the installation of win8.
If somebody knows about this issue please let me know
Adobe Premiere not working, error – LoadLibrary failed error 126
You can resolve this issue by follow few methods.
Method 1:
This error is related to the generally graphics card driver provided with the Widows installation as well as happens mainly with AMD/ATA based solutions. So to solve this problem download and install the latest version of the Graphics card driver for your hardware. You can download latest one NVIDIA or Intel Express 3D Graphics card driver from here. If your update driver is not work properly visit this site to get information.
Method 2:
You can perform a system file checker scan on your PC.
1. To perform this technique, first of all close your open programs on your PC
2. Click on the “Start” menu.
3. Type "cmd.exe". Right-click on it and select "Run as administrator".
4. Now type the following command in the console box: sfc /scannow
5. Hit enter.
Method 3:
1. Go to the “Start” Menu >> Select “All Programs” >>Click on “Accessories”>>Right-click on “Command Prompt” >> select “Run as administrator”.
2. Now type the following commands and press “Enter”.
1....
