Fiannfriday
Posted on - 08/19/2011
Hi dear,
I am trying to install adobe premier in my computer, but SSE2 instruction set support error occurred.
Please tell me its solution how can I install this program or some lower version of this program. I wait for your answer.
Complete Error detail is displayed here so that you can understand error easily:
Adobe Premiere Pro 2.0 Setup
Installation Error
SSE2 Instruction Set support
Adobe Premier pro 2.0 cannot run on this computer because the processor does not support the SSE2 instruction set.
Cancel
Regards
NeoTech
Adobe Premiere Pro 2.0 SSE2 Instruction Set support error
Fiannfriday,
The error specifically pointed out that the processor you currently have does not support the SSE2 Instruction sets. You only have two recourses here, upgrade your processor to CORE 2 DUO or i3 or i7 cores for the installation to continue, or install a lower version of Adobe Premiere Pro that would support your present processor.
Utilizing tweaks on your machine to fool the application into continuing to install may not be a good idea because the application once it works is very hardware-dependent and you will keep getting hardware-related errors when you use it.
Note: if you have successfully installed Adobe Premiere Pro into your machine, please consider upgrading your memory to at least a 6 GB size to accommodate the application's hunger for memory usage. ( Just my two cents)
Upgrading your video card to at least 1GB 256 bits is a plus too.
Happy Computing,
This error is obviously related to hardware. Before installing the program, check the system requirements and make sure your computer meets those requirements. Adobe Premiere Pro 2.0 supports Windows XP (Professional or Home edition) Service Pack 2.
It requires 1.4 GHz Intel Pentium 4 or faster processor with SSE2 support, 512 MB RAM, 4 GB free space, sound card, 32-bit color display at 1280 × 1024 screen resolution, and QuickTime 6.5. Since that error points directly to your processor which lacks SSE2 support, you cannot install the program until you upgrade your processor.
To check the features supported by your processor and to verify if SSE2 is supported or not, download CPU-Z.
