Have a look at the error message mentioned below. It is indicating that Premiere Pro has encountered an error.
Have you any idea for this error. Please help me.
Thanks in advance.
[/Volumes/ BuildDisk/builds/ringo64/shared/adobe/
MediaCore/AudioRenderer/Make/Mac/../../Src/
AudioRender/AudioPrefetch.cpp-87]
Adobe Premiere Pro has encountered an error when opening
Hello.
This might be due to the registry errors. May be the registry memory has been relocated. You need to clean everything related to premier pro by using adobe cleaning tool. To know more about adobe cleaning tool and to download click on the link below.
https://helpx.adobe.com/creative-cloud/kb/cc-cleaner-tool-installation-problems.html
Once you clean everything you need to again reinstall premier pro.
Thank you.
Hello Jair,
The error problem you have mentioned, many people are facing the same this days. To resolve the problem you can try a few things. At first close the adobe premiere or any application is running. Then go to users then your user name (library/Preference/adobe/premier pro). Now rename the folder called 6.0 to old 6.0. After that, restart it again. Hope this time the error won't show up. You can also try the adobe cleaning tool.
Hope this will help.
Thank you.
