Hi Experts,
I have received an awful error message regarding Printing. The error message “Printing Error. The Adobe Print Engine has failed to output your data due to an unknown problem” appears frequently.
I do not understand this error message. If you have any idea regarding this issue please help me.
Thanks in advance.
Do the following:
1. Exit InDesign.
2. Rename the SavedData file in InDesign and incorrectly the Defaults file (InDesign SavedData.old, InDesign Defaults.old) into the following directories –
Windows XP: C:/Documents and Settings/[user name]/Application Data/Adobe/InDesign/[Version]
Windows 7/Vista: C:/Users/[user name]/AppData/Roaming/Adobe/InDesign/[Version]Mac OS: /Users/[user name]/Library/Preferences/Adobe InDesign/[Version]
3. Now open InDesign. InDesign will create preference files.
So the old preference files will be replaced by new ones and your problem should be fixed.
There are lots of solutions for this problem, 11 to be exact. And applying any one of them can help you solving this problem you are having.
Visit this page: Error print engine failed to print
There are some 11 solutions to be tried on this official support site, as well as some more information that might help you to set up your system not be in the same frustrating situation again.
Hi Rachel Girfiths
You can solve this issue by applying another technique. To get that, go this Techyv page "Printing Error-adobe print engine has failed" and get more idea.
