There is a problem that occurs when installing Adobe Reader 11.0.3 patch on Windows 7 64-bit. The error is as shown below. Any suggestions?
The upgrade patch cannot be installed by the Windows Installer service because the program to be upgraded may be missing, or the upgrade patch may update a different version of the program. Verify that the program to be upgraded exists on your computer and that you have the correct upgrade patch.
points
Adobe Reader 11.0.3 installation error
Adobe Reader is a great PDF reader that has been made by Adobe Systems Incorporated. There are many updates available for this PDF reader along different patches.
Patches help your Adobe Reader give you better performance.
The error you have got might be for trying to install improper update. Every specific version has got specific patch.
Here, there are all the updates and patches for all versions of Adobe Reader.
Also, you can re-install the Adobe Reader. Somehow, this program has been removed from the database of Windows Installer. Reinstalling will re-register it into the database.
