noel_dy
20 points
Posted on - 09/15/2012
Hi All! I was installing Adobe Reader 9.3 when it was almost done this Error: 1935 just went up. What causes this? I tried downloading another installer but still. Is it the download source that has the problems?
Error 1935. An error occurred during the installation of assembly component.
{98CB24AD-52FB-DB5F-A01F-C8B3B9A1E18E}
HRESULT: 0X80070005
Adobe Reader 9.3 installer information
Error: 1935 An error occurred during the installation of the assembly component
Noel
Adobe Reader 9.3 Error: 1935. Installer problems, what to do?
Hello.
There might be a problem with the installation source.
Try to download the latest version of the software.
In some other case there might be a problem with the compatibility issue of the software with the operating system.
Click on the below link to download the windows 7 compatible software.
https://get.adobe.com/reader/
Thank you.
eally
Step 1: Start the Task Manager.
Step 2: Behold the Processes tab. Look for a process named wtoolsa.exe.
Step 3: If this process is running, then you remove this adware.
Step 4: Install Acrobat or Adobe Reader again.
If this solution doesn't work
