While I was reading a book in PDF format with Adobe Reade this error appeared on my desktop and after OK the program closed. How can I fix this error ? Is there another PDF reader, better than Adobe Reader ?
Thank you experts !
Adobe Reader
Une erreur est survenue lors du traitement d’une page. Une erreur est survenue a la lecture de ce document (18).
Adobe reader error loading a pdf document
The French message in the dialog box “Une erreur est survenue lors du traitement d'une page. Une erreur est survenue a la lecture de ce document” translates in English as “An error occurred while processing a page. An error occurred on reading this document”. The Adobe Reader was unable to open the PDF file because the file has a problem.
If the file is a book then there is a problem with one of its pages. If you downloaded the PDF file from a website, make sure you downloaded the file completely because you will not be able to open it if it is incomplete. Try downloading the file again and this time make sure it is completely downloaded.
You may also try updating your Adobe Reader to the latest version to make sure it is compatible to open the PDF file in case the file was created using a much newer version of the Adobe PDF software. Whatever version of Adobe Reader you may have, download and install the latest, Adobe Reader XI [11.0.08]. It requires Windows XP Service Pack 2 x64, Windows XP Service Pack 3 x86, Windows 7, Windows 8, and Windows 8.1 both x86 and x64.
For servers, it supports Windows Server 2003 R2, Windows Server 2008, and Windows Server 2008 R2 both x86 and x64.
