ricky long
30 points
Posted on - 09/17/2012
I was unable to open my Adobe Reader. It is showing “Not a supported file type” and all my desktop icons were changed into Adobe symbol such as IE, Amazon and Firefox. I tried restarting but it still the same. I could not even download anything. What is the reason for this? I even tried repairing Adobe installation on Adobe website but nothing happens. Please help.
Adobe Reader Error: Not a Supported file Type
Hello.
There might be a problem with your adobe reader.
The adobe reader might have been malfunctioned.
Try to uninstall the adobe reader from your system.
And install the fresh copy of adobe reader.
Click on the below link to download adobe reader.
https://get.adobe.com/reader/
Select your version that is compatible with your operating system.
Thank you.
Hello Ricky,
To resolve that issue, do the following;
Click the Start button, and then 'Control Panel'.
After that click 'Default Programs', and then click 'Associate a file type or protocol with a program'.
In the list that appears, you will need to locate '.acsm', click on it to highlight it, and then click 'Change program'.
After that, choose 'Adobe Digital Editions' and then click 'OK'.
Repeat steps 4-5 for the '.epub' extension as well.
Carl
