This problem may arise due to many reasons, so that there could b many solutions for this, few expected solutions are here,
1. Recheck your printer settings, check preferences settings. Reset printer from Photoshop page setup. <Choose File< Print <Click Advanced Button at the bottom <Choose the file you wanted to print Click < Print. Restart Photoshop and try your printing process again.
2. Check your printer's drivers are installed.
3. By creating new user account your problem may be solved.
Had you checked the driver of your printer? Is it installed or not? If not then install the driver by going to:
Start > Control panel > Devices and printers.
And try again else you need to upgrade the latest version of the driver. Or you can also try to unplug the wire of your printer and then reconnect it again and then restart your system and check now. If you face the same problem then try to print some document from somewhere else. If it prints then there is a problem with your adobe reader. Update it or reinstall its latest version.
This means Adobe Reader was unable to detect a printer on your computer. Before you can do a print with Adobe Reader or any other application, a printer must be installed on your computer. If a printer is already installed, make sure it is turned on and connected to your computer when you do the print so the application is able to detect it.
On the other hand, if the printer is already connected and turn on but it can’t still be detected, try transferring the cable to another USB port. Use all available USB ports as possible for further troubleshooting. If the problem continues, try using a different USB cable from a working printer or connect the printer to another computer and see if the printer works there.
If the printer works on the other computer but not on your computer, there might be something wrong with your USB ports. See if you can connect and detect other USB devices on your computer. If the problem is with your USB ports, try to uninstall and reinstall the USB driver. Click “Start” then right-click “Computer” and select “Manage”.
In “Computer Management” window, select “Device Manager” on the left pane. Now, expand “Universal Serial Bus controllers”. Right-click the first item and select “Uninstall”. Repeat this on the remaining items. When you are finished, restart the computer. Windows will reinstall the USB drivers back on startup.
1....
