Adobe Reader There was an error opening this document. Access denied.
I have my term paper due in a month. Our professor asked as to pass it in PDF format so I installed adobe acrobat reader 11. I did try to create my paper from Microsoft Word 2010 and pressed Save as a PDF.
As I am opening my file in the acrobat reader something popped out that says “There was an error opening this document. Access denied”. I did not put any password on the file so what seems to be the problem with it?
Adobe Reader
Answered By 5 points N/A #177461
Hello Richard
I may be able to help you with your problem. First, try the following solution. Launch Adobe Reader, go to Edit – Preferences, and in the left click on Security (Enhaced) and uncheck the box that says "Enable Protected Mode at startup". Exit the application and try opening the document again. It should work just fine now.
I hope you will find this information useful and it will help you solve your problem.
Randolph
