Adobe Reader updation was interrupted with an error message
Asked By 290 points N/A Posted on -
Hello Team,
I have something to discuss about the file transfer error which I faced today morning. I have installed Adobe Reader on my desktop to open PDF file formats. During the software updating, it was interrupted with an error message saying, unable to open transfer file.
I was wondering what this message is related to. Kindly fix my problem and make the necessary changes so that I can open the document.
Answered By 0 points N/A #195130
Sometimes during the installation of Adobe Reader an error occurs which may fix within few steps. When you install your Adobe Reader an error indicates that there is a partial installation of Adobe Acrobat or Adobe Reader.
To fix the error, uninstall any previous version of Adobe Reader and Adobe Acrobat. You need to run the Windows installer Clean UP Utility to clean the files of any traces of previous version.
Download the free Windows Installer Clean UP Utility from any shareware download site.
Run the ‘’.exe’’ file, and then install Adobe Reader.
