Adobe Reader version error occurred
Hi everyone,
Which version of Adobe Reader should I use to solve the error message shown below? Currently I have adobe reader 9.
This document enables Reader capabilities that are no longer enabled in this reader version.
Answered By points N/A #167220
Hello Christopher!
You are using Adobe Reader for reading PDF files.
The PDF file is created from any document using PDF creator software. The softwares create PDF using a coding system. There are various versions of this coding. The older Adobe Reader versions support the coding that was used to create the PDF you are facing problem to open.
You can use a software called “PDF Version Converter”. It is a tool that converts the older versions of PDF files into the latest PDF coding system. It is able to convert PDF files that are compatible to read by any Adobe Reader version.
Hope got no more problem.
