I am having some issues with PDF Files.
I got errors when I try to open PDF files within external email programs(Microsoft Outlook Express, Microsoft Outlook 2003, 2007, 2010, Windows Live Mail, Eudora, Mozilla Thunderbird etc) and Adobe Reader X (10).When trying to open up a PDF using one of these external email clients or others, Adobe Reader X launches and gives the following error message:
There was an error opening this document. Access denied.
Adobe Reader X Error on Opening PDF Files
If the file is still from the internet and you just want to download it or just open it online, you better uninstall your adobe acrobat reader X and just re-install it after restart to make sure it will be a fresh copy you install in your system and not to just override the corrupted installation.
Often times that error occurs when the file is virus infected. So whenever you open that file, the anti-virus will block that specific file to avoid further damage to your system. Better scan your computer to check for further virus infections. Some viruses maybe unexpectedly residing within some of the system folders.
