Rein Thomas
Posted on - 02/07/2012
Not long ago I have installed Adobe Reader X on my computer Windows XP SP 3 and every time I click and run the program it crashes. I attached the error message below. Could somebody help me and fix the issue?
Thank you in advance.
Microsoft Visual C++ Runtime Library
Runtime Error!
Program C:Program FilesAdobeReader 10.0ReaderAcroRd32.exe
Abnormal program termination
Adobe Reader X crashes in Windows XP SP3
Hi there,
just right-click on the AcroRd32.exe and chose properties. then Compatible Mode.
Then i chose Compatible Mode > Run Program in Compatible Mode
for and there i chose Windows 2000. click on OK and start the exe or a PDF.
runs now without any problem. don´t know why :=) but it works for me. hope it could be helpful for you.
If it doesn’t work try the following:
try uninstalling Acrobat, Air, and the C++ runtime libraries. (When upgraded to the 2008 libraries, notice if the previous version on your computer (2005) is there or not. If so, uninstall both versions.) Then, install the 2008 C++ libraries, followed by installing Acrobat Reader X (and its payload of Adobe Air).
Everything will works fine, as far as I can tell. Hovering the mouse over a desktop PDF file will not throw a runtime library error, and the Reader plugin in Firefox will also work fine too.
