There is an error message appearing in the Dual Core Center and it seemed that this is not functioning well.
I am completely hopeless with this matter. Kindly elaborate on this.
Dual Core Center
Dual core Center does not support!
Adobe Reader X halts on wicked PDF spam campaign
Greetings,
It's unfortunate that you ran into problems while using DualCoreCenter.
You may want to try updating to a later version of Dual Core Center Click here.
Also, you need to check if you have Microsoft .NET Framework 2.0 or higher. If not, download it here.
If the above suggestions didn't work, perhaps your system isn't supported by DualCoreCenter. In which case,
You may try CoreCenter.
If all else fails, perhaps it's true what people say about this utility. If over clocking or control of fan speed is what you need, there's a bunch of good utility software out there.
Check out MSI's After burner.
