Hello experts,
I am getting this error occurring for various apps, Adobe Shockwave Player for example, on my system and can’t work out why. The message appears when I try to uninstall either using Windows uninstall or the Uninstaller manually. Does anyone experienced such an error before ?
Thank you !
NSIS Error
Error Launching Installer
OK
points
Adobe Shockwave Player Launching installer error NSIS
NSIS is a great program installation solution for Windows using MSI installer. As you’re facing problem with the installer file, your setup file is, probably, corrupted.
This might be because of corruption from downloading or obtained from scratched CD/DVD.
If you’ve downloaded from internet, double-check that the file is downloaded properly. You can use any good downloading manager for downloading your files safely and corruption free. Download IDM, FlashGet, EagleGet etc. They are some of the good download managers.
If obtained from a CD/DVD, then get another copy because the existing one might be corrupted.
After you’ve obtained a fresh copy of your setup file, run the installation process and it should go fine.
