Adobes’ Lean Print utility features
This cost saving utility doesn’t seem to work on my Google chrome software. What might be the problem?
The Adobe Lean Print Utility has made our printing problems lessen. It is a new software developed to minimize printing costs with lots of good features while increasing the productivity of our printing outputs. It is exciting to know that Lean Print has its innovations to track printing jobs and analyze the paper and toner savings to use at a document. Offices, homes and anybody will love to use this software. But it is a frustration that Adobe’s Lean Print doesn’t have lots of programs being supported. It has limited applicability. Lean Print does not support Google Chrome. It only supports Firefox (not its latest version) and Internet Explorer.Â
That’s true. Even if the new LeanPrint from Adobe considerably lowers your expenses on the paper, toner, and or ink you use, still the programs it supports are very limited. It doesn’t work on Google Chrome as well as the latest version of Mozilla Firefox. It also includes in its list of unsupported applications any applications from Microsoft Office excluding Microsoft Office Word and Microsoft Office Excel.
Its PDF support might also have a problem since it only supports Adobe Reader 8 and later versions. Any earlier Adobe Reader versions will be incompatible. To define Adobe LeanPrint, it is an enterprise-class, software-only printing solution. The keyword “software-only” obviously states that it doesn’t use any toner or ink for the print besides the paper. This will surely reduce the cost on your printing jobs. But even if it really sounds good, it still has a lot of problems considering what PC Advisor has to say when they test it. See what they have to say on Adobe LeanPrint review.
The Adobe LeanPrint
In my free time I always try to visit Techyv.com. This site helps me to relive the boredom from my routine bound work as well when I face any problem I come to this site for solutions too. Hi guys all of your comments were good but true to say, Sharath your comment was after my mind because seeing your free and easy solution my heart leaps up with joy that by following a simple process I can fix my problem which was hanging heavy upon me before reading your solution. I also didn’t know that it only supports Adobe Reader 8 and the latest version as well by visiting your provided link I have learned many information which were not known to me. Thanks Sharath for enriching my knowledge. You’re a great solutions provider. Job well done.
