ADO.NET ADDING IN DATA ENTY
For adding this model ADO.NET data providing software works best.
http://www.firebirdsql.org/en/net-provider/
The above address holds various versions with different types according to the extent of use including packs, files and tools. Keep downloading and installing one by one until your desired version or desired addition is not fulfilled.
Another address: http://docs.openlinksw.com/virtuoso/vdbenginefirebd/
Hello Wamaeallan !
You can use the “Virtuoso” Framework which is compatible with the ADO.net system. The Virtuoso ADO.net framework provider can be employed to query the remote Firebird objects connected to the virtuoso Server. For connecting to the desired database you must install the Firebird ODBC Driver .It should be accessible with a configured DSN .After downloading and installing Firebird from Sourceforge.net you have to complete the following steps.
Step 1:
You should download ADO.net provider from this site: http://docs.openlinksw.com/virtuoso/virtclientref/
Step:2
Then the Firebird tables should be linked into OpenLink Virtuoso
Step 3:
Then login with Conductor link.
Step 4:
Fire to Firebird DSN.
Step 5:
After connecting DSN select the link objects button to obtain a list of available tables.
Step 6:
You have to rename all the catalogue to “Employee”.
Step 7:
After linking tables these will be viewed under “External Linked Objects” tab.
Hi there,
You will have to verify this work to see when they contain a typical style. Verify
should they almost all contain the pursuing:
<packaging>bundle</packaging>
You need to look at altering this product packaging in
order to warfare or even container if ever the works are able to obtain the resource
folder correctly.
Take care,
Barkey Lara
Hi there,
The Best Software for adding this model ADO.NET data providing. http://www.firebirdsql.org/en/net-provider/
The above mentioned street address keeps different
types using different kinds based on the level useful which includes delivers, data
files and also methods. Retain downloading it as well as setting up1 by 1 till your
own wanted model or even preferred add-on isn't satisfied.
Alternative address: http://docs.openlinksw.com/virtuoso/vdbenginefirebd/…
