Adprep was unable to modify the security descriptor on object
When I am trying to use Adprep, it encountered an LDAP error. The error indicates "Adprep was unable to modify the security descriptor on object".
They are the following:
CN=DomainControllerAuthentication,CN=Certificate Templates,CN=Public Key Services,CN=Services,CN=Configuration,DC=xeroxtoledo,DC=com.
CN=DirectoryEmailReplication,CN=Certificate Templates,CN=Public Key Services,CN=Services,CN=Configuration,DC=xeroxtoledo,DC=com.
CN=KerberosAuthentication,CN=Certificate Templates,CN=Public Key Services,CN=Services,CN=Configuration,DC=xeroxtoledo,DC=com.
The credentials I used while using Windows Server 2008 is mydomain.
Can anybody help me fix this issue?
