ADR 2012 installation issues / errors
I am facing an error while installing the ADR 2011 MSI [setup file], by using command for creating a log file. It is also to inform you that I am running Windows 7 [having 64 bits operating systems] and 64-bit computer system.
Please examine the screen shot of that error message [attached].
Error 1713. There is a problem with this Windows
Installer package. A DLL requires for this install to
complete could not be run. Contact your support
personnel or package vendor. Action
_560A25DD_C4DE_4BC1_92AD_536652FFBE95.
entry: Uninstall, library: C:Program Files
(x86)AutodeskAutodesk Design
ReviewUPIUPICA.dll
OK
Secondly, I also tried to execute the exe file with the installer and faced other error messages, and finally not succeeded.
Please help me out of this issue as soon as possible; I am waiting for your kind responses.
Thanks in advance.
