Ads Instant HDTV PCI Code 10
Why do I get this error code 10? It says ‘the driver could not start.’ How can I solve this problem?
The code 10 contains ‘fail reason string’ which indicates the error message by the hardware manufacturer. The error code 10 of HDTV PCI occurs when the drivers that you have in the device does not start or respond to the command. The error code 10 indicates incompatible, or an outdated or may have occurred due to corrupted files. To solve this problem you need to go to the Control panel, choose the view you like then right-click to the devices that are listed and select the option “show disable devices: This will enable your hardware and start working.
Notifications
