Hi TechyV friends!
I want to optimize my laptop for gaming. Also I want to optimize it’s battery life because everyone wants more laptop battery life without having to plug it in all the time for charging it. My question is, How can I do it? Is there an advanced laptop optimization method? Any help would be nice.
Thank you very much.
Cooper Rmyles
An advanced laptop optimization method
Hello Dear,
Yes, There are many methods which you can use and optimize your laptop speed. Fist method is that remove all unnecessary programs from the laptop. Remove also start up programs. Then go to start menu and write “Run” in the search box.
Press enter then Run box window will open and now write in the run box “msconfig”. Press enter then a window will open after that go to startup tab and see the unwanted application and unmarked them.
There is also some software which can help you with this issue check this website. There is also a very nice article written with full guidance of optimization of computer/laptop, check this website and There is also a website from which will help you in optimization of the laptop battery.
Hope this will help You.
Hi cooper Rmyles,
Have a nice day.
To optimize your laptop performance for gaming, follow these steps:
1. Remove all unwanted programs from add remove icon found in the control panel.
2. Run a scan on all your hard drive partition.
3. Open task manager and stop all unwanted processes from the list.
4. Clean your C drive registry error (it's very important).
5. Increase your VGA card, try to purchase an NVIDIA card for gaming.
Hope this will work.
