Hi there,
Advanced Turbo Flasher gives me this error when I want to connect my phone and access my account. Is for the first time when I have this error and I don’t know hpw to manage it. Anyone can help me please to fix this ? What is causing this error ?
Thank you !
AdvancedBox Turbo Flasher
Invalid file name-%s.
Acceptar
Advanced Turbo Flasher says Invalid file name
If you have been using Advance Turbo Flasher before without a problem, try restarting your computer and try again. Also, since you are only using version 9, try updating the program to version 9.40 or higher. To find a suitable update, visit ATF Super CMLA Repair. Try following the instructions on the page. The site doesn’t provide a direct download for the latest version.
What the site provides is an old version, Advance Turbo Flasher 8.70. The program is not free and in order to have an upgrade, you need to purchase it. To fix the problem, uninstall Advance Turbo Flasher 9 and then delete the folder “C:AdvanceBox Turbo Flasherfolder”. “folder” is the name of the folder to delete. After that, click Start, All Programs, Accessories, System Tools, and then Disk Cleanup.
Select drive C and click OK. Check Recycle Bin and “Temporary files” and then click OK. Restart your computer and then install Advance Turbo Flasher back. If it doesn’t work, uninstall Advance Turbo Flasher again then delete the entire folder “C:AdvanceBox Turbo Flasher” before reinstalling Advance Turbo Flasher.
