A few days ago I had a problem that I found my advanced volume control is missing from Taskbar and then I tried to find the function in control panel>sounds,speech and Audio devices and then clicked in Advanced volume control and then I found a dialog box which is given below. Would you tell me how I can get rid from this problem?
Windows cannot find 'C:WINDOWSsystem32sndvol32.exe'.Make sure you type the name correctly,
and then try again. To search for a file click the Start button, and then click Search.
LheaP
Advanced Volume control Is missing from Taskbar and not working?
Hi!
Your problem regarding 'the advanced volume control is missing from taskbar', is maybe a cause of virus, malicious file, system file corruption, applications erro, and hardware failure. In order to resolve this problem, you may follow the following procedure to isolate the error.
Update Antivirus and scan your computer
1. Install Malwarebytes to scan for virus and Malware
2. Check device manager, to check your hardware device
After scanning your computer for potential threats from viruses, please check your audio driver by accessing device manager. If you see an exclamation icon, you must install your audio driver again. Please see the procedures (Device Manager).
1. Right click My Computer and select Properties
2. Click Device Manager and select Audio
3. Right click Audio and update driver
LheaP
kimanif
You can get rid of this problem by insert the Windows XP installation CD into your computer's CD or DVD-ROM drive. Press and hold down the SHIFT key as you insert the CD-ROM to prevent it from starting automatically.
After that press Windows logo + R to open the run dialog box. In the Open box, type cmd, and then click OK.
(Type the letter associated by the CD or DVD ROM for example d represent the CD or DVD ROM drive)
Type
D: (press enter)
cd i386 (again press enter)
expand sndvol32.ex_ system_rootsystem32sndvol32.exe (again press enter)
exit (press enter)
Note: type exactly as shown above. Verify if the volume icon is in notification area.
