Advantage Features of Windows OS
In Windows OS, the search system has been refined so it is easy and fast to navigate. And also, the used memory spaces has been made very effective to ensure that it would have a fast and firm performance restructure for enhanced power management through the decreasing background activities.
It hassupport on 64-bit PC, wireless media streaming and it also has the touch screen feature when pairing with a touch screen monitor. Additionally, it has the newest Call Jump Lists tool that makes it easy to access your most used programs.
Windows OS is the most popular OS in the world. There are several reasons for that,
User Friendly
New user can work without gaining much knowledge on the OS, but most of the others can’t do. Windows Desktop is the User Interface of all the versions of Windows OS. It is more users friendly with the Icons, Start menu and Taskbar. New users can understand and memorize the commands easily.
Multitasking
Multiple applications can run at a time.
Resource Management
Its mange resources like memory themselves
Hardware Compatibility
Window OS have design to compatible with a large amount of hardware on variety of manufactures (Motherboards, Processors, Memory Cards, Keyboards, Mouse, and USB Devices etc).
Software Compatibility
Most of software vendors develop software’s that are mostly compatible with Windows OS. Some software’s in the market only compatible with Windows OS
