Advantage of using memristor in storage technology
What is the advantage of using memristor (technology invented by HP) on manufacturing of hard disk?
Will it be cheaper than the current technology?
Advantages of Memristor:
1. When used on a data center and the power is interrupted, it gives consistency and flexibility.
2. It has a substantial data density.
3. It is cheaper but faster than MRAM.
4. It generates lesser heat and less energy.
5. If your device is close, it allows faster boot up and the information is still intact.
6. It makes a computer not to boot up.
7. The density allows us to store more data.
8. You will not lose data even if it is turned off.
There are some advantages of using memristor.
It is less expensive and faster then other device like MRAM.
There are more capacity to storage more information.
It is dose not lose information when system are switch off.
It has importanat information dansity.
It is use less energy and produced less heat.
it has option to combined one short device, hard drives and working memory.
Thank you Tunacao_Caaron1 and Adeel77 for giving me a list of the advantages of Memristor.
Your responses really helped me.
Many thanks TechyV!
Dear Philippe,
There are many advantages of Memristor technology. Some of them are given below
1. It contain more data at a time.
2. It has greater data transfer rate.
3. It is a reliable technology.
4. It is a very small device,
5. It is easily transportableÂ
6. It kept data when its turned off.
7. It use less energy.
8. The cost of Memristor technology relatively low
Thanks and Regards
Louis.
