Advantages And Disadvantages Of Operating System Linux?
What are the advantages and disadvantages of operating system Linux? I am thinking of switching from Windows so if anyone could help with this, it would be great.
Answered By 15 points N/A #95890
Here are the top advantages of Linux:
1. If you are an economical person, you will find one of the best uses of Linux in the high number of distros of Linux.
2. Stability of Linux systems are high and they seldom, if ever hang
3. They are faster and more efficient, because they use less RAM per program.
4. It’s the most secure computer system.
Here are the top disadvantages of Linux:
1. If you need to use any Windows software, you might be disappointed because compatibility is limited in Linux
2. User friendliness: Even though Linux is user friendly, if you haven’t had a chance to use it before, you will find it very different and time taking for a little while.  
