I am planning to buy a new netbook. My old model is an Acer and I'm considering shifting to other brands. I have an eye for this particular model, Dell Inspiron N1050. It is within my allotted budget, but I want to know what is the advantages of the Dell Inspiron N1050 over the other models?
Advantages of Dell Inspiron N1050 over other models
Hi!
This is the features of Dell Inspiron N1050 core I3
* Processor 2.4GHz, 3MB
* battery last more than 2hrs
* DVD (it is Super Multi DL drive)
* 2GB DDR3 Memory
* SATA is the type of hard drive
* Maximum memory capacity up to 8GB
All advantage of other laptops can be seen in the features given above. I hope this will help you decide
You need to look at the battery and the adapter. If in case the battery is not inserted then in that case you need to insert the battery properly. You need to check the adapter as well. If both of them are ok then there might be problem with the power plug. You need to check that as well or else you need to contact Dell customer care with your warranty details.
Waters Magner
