Advantages of using nofollow attribute in html
What are the usefulness or facilities or advantages of using in html coding?
Best Answer by Head Jonathon
Answered By 80 points N/A #121305
Here are the benefits of nofollow links:
  1. You can still get traffic from nofollow links, provided that you have good backlinks, this is going to be beneficial even though you have a nofollow link
  2. The search engines will still the nofollow link to index your page in some cases
  3. Having dofollow is quite suspicious so it is better that you also have a nofollow link to avoid suspicions
  4. Search engines won’t let nofollow links hurt your own site’s ranking
  5. Other search engines still use the nofollow links in determining rank wherein nofollow links may still have parts in search algorithms
Answered By 0 points N/A #121306
Hi Fred,
Nofollow is a value that can be assigned to the relattribute of an HTML .This is used to command some search engines that a hyperlink should not influence the link target's ranking in the search engine's index. The syntax of relattribute is <a rel=”value”>.One such value is nofollow. The search engines have great importance on how many links a site receives. So spammers take advantage of this. By embedding an instruction like nofollow  in comment templates ,it tells  search engines to ignore links in comments.
In this way we can avoid spam links.
Thanks!
